greaseyfingers
- Nov 4, 2007
- 1
- Age
- 52
- Crookston, Mn.
- Ford
The number 2 cylinder fuel injector isn't firing on my Ranger's 2.9 engine.
The fuel injector's ohm resistence measured 15 ohms.
I think 15 ohms is within specs, isn't it?
When I grounded my continuity tester and checked for power on the fuel injector's wire connector plug terminal.
The continuity tester's light comes on when I touch it to each of the wire terminals on this connector.
On this fuel injector wire connector, isn't one of the two terminals suppose to be for power and the other one for a ground?
Why would it be lighting up the coninuity tester when touching it to each individual termanal on the fuel injector's wire connector plug?
Has anyone had this problem, before, and what's the remedy to fix it?
