I know I am still bouncing around between sub-assemblies a little and have not had a chance to start color sanding and polishing the cab. The weather is back and forth, cold and dry or warm and wet. Color sanding seems to keep taking a back seat to other items on the check list.
I picked up a few salvage pieces late last week that I will need soon. Clutch pedal assembly and supporting pieces, factory manual shifter & boot, manual shift steering column trim piece (upper), 2011 OE Ranger hood panel and hinges, cab/roof molding trim piece(driver side), etc.
The clutch pedal assembly was the first of these items to hit the cutting block!
A frequent issue with manual shift V8 Rangers is adequate clutch disengagement. Depending on the application and choice of parts there just is not enough travel when using the common donor slave cylinder with the OE clutch master cylinder. Most will agree that the issue in question is matching the smaller bore diameter clutch master cylinder to the larger bore diameter slave cylinder. The clutch master cylinder can’t move enough fluid to push the slave cylinder to the maximum amount of travel. Most people overcome the problem by sourcing a larger diameter clutch master cylinder.
My thoughts were pretty simple, if small truck equals small clutch master cylinder, big truck should equal big clutch master cylinder! It makes sense right? I picked up one for a 99 Ranger and one for a 99 F550 for comparison.
Sure enough, the one for the F550 was slightly larger both in bore diameter and length of travel while still sharing the same basic design. The mounting configuration is identical except for the overall diameter of the unit. In the following photos you can see that the larger F550 piece will not fit through the small opening in the pedal bracket without minor modification.
99 Ranger piece.
F550 piece.
Ranger piece in bracket, F550 piece in hand.
By enlarging the mounting hole in the pedal bracket I was able to mount the F550 clutch master cylinder in the OE location.
The pushrod and backup/neutral safety switch from the 99 Ranger piece will be used with the new F550 clutch master cylinder. However, the new F550 clutch master cylinder not only has a slightly larger bore diameter but also allows for more travel. I would like to take advantage of the longer travel as well but will need to modify the clutch pedal and neutral safety switch in order to do so. I am still working through that mod and will revisit it at a later time.
99 Ranger piece. 1 1/2 inch travel.
99 F550 piece. 1 5/8 inch travel.
Approx. 1/8 more travel with the F550 clutch master cylinder.
