Nope!
Ok I used a candy thermometer stuck into the radiator and got like 7 Degrees less than what my gauge was reading. So are you suggesting I run some coolant that isn't water based? Although I did get it to puke with the radiator cap off but that was to be expected.
I'm saying you have an imagined problem.. Your ride will most likely stay in the NORMAL range on your stock gauge! You have installed another gauge that is alarming you unnecessarily. Wait until it pukes out it's coolant and then worry about what caused the overheating. The temp rise in stop and go traffic in the middle of summer is NORMAL!
As for coolant that won't boil.. PURE ethylene glycol will get icy/slushy at around 0* F. But it won't boil till about 400*.. So if you don't expect your ride to see below 0*, running pure ethylene glycol would be advised for all engines.
Since the pure ethylene glycol doesn't have water in it and is an oily liquid your coolant pump will last nearly forever and there will no NO RUST in the engine. Adding water to ethylene glycol actually lowers the temperature at which it begins to turn to an icy/slushy mixture.
Here in central Texas I always use the pure stuff and never mix water in it. I have visited all the western mountain states in the fall early winter with no bad results. However I am aware that the pure ethylene glycol will freeze and bust engines in certain parts of this country.
I do own a Bobcat. My Bobcat has about 5 gallons of 40W oil in it. This 5 gallons is circulated thru all the engine components. It goes thru the cooling jackets and thru the radiator and then thru the engine lubricating it.. THAT is all that is in there! 40W oil! So see, water isn't needed to cool an engine.
Big JIm
