Avyn Nix
- Jul 16, 2023
- Reaction score
- 11
- Location
- California
- Make / Model
- Ford Ranger XLT
- Engine Type
- 4.0 V6
- Manual
- 2WD / 4WD
- 4WD
- Total Lift
- Stock.
- Tire Size
- 30in
Ron,You can pull the vacuum hose off EGR valve with engine running, and feel the end of the hose with your finger, should have NO VACUUM at all
Then put your own vacuum hose on the EGR valve and suck on it, no there will be no exhaust, or there better not be, lol
As you "pull a vacuum" by sucking on the hose, the idle should start to deteriorate, stumbling, release vacuum and idle should return to normal, if it hesitates to return to normal then EGR valve could be sticking a bit
Purge valve leak should show up on IAC valve test, so not an issue if idle dropped
Would be a long shot but exhaust manifold leaks on BOTH banks could cause False Lean, these suck in fresh air, which O2s see as "air in exhaust" so lean burns
Check a few spark plug tips to see if they are darker brown this would indicate False Lean so engine is actually running richer than it should
But this can also be a computer issue
LTFT(long term fuel trims) can take some time to come down after repairing an issue
What are the STFT(short term fuel trims) on both banks, say when cruising along at 40MPH steadily?
The way Fuel Trims work is this
Computer calculates Open Time for injectors, and that is STFT 0%
It then ADDS LTFT to that, in this case STFT 0 is really STFT +25%
So if you don't see STFT as -10% or so then problem is not fixed
LTFT is there so the system can "age gracefully", lol, and computer does not need to RELEARN the system at each startup
There will always be small air leaks, MAFs get dirty and fuel pressure will vary over time
So LTFT of +10% is not a concern
This is why computer adds LTFT to its calculation before using it, it is adjusting the air/fuel mix for Long Term use in this specific vehicle
So if there was a problem like a vacuum leak which caused STFT to go high it would also cause LTFT to go high over time
When air leak is repaired then when the high LTFT is added to computers calculation the STFT would then go into -10% STFT because its now too "rich" with addition of LTFT and then this -10% will pull down the LTFT over time
Thanks for the info on how the fuel trims work. We were not seeing the -#'s like you stated..
I'll go get the data at 40mph after i get back from the parts house.
I put a syringe on the egr vacuum port and was able to pull both a vacuum and hold pressure, I'll do the running check later..
I also checked the EGR vacuum solenoid, it appears to be stuck open, can freely pass air through vacuum ports and the breather port on the top, this would easily be a vacuum leak. Soap test did not find it due to it under a plastic cap and covered by a small foam filter.
Everywhere that was not power washed has a thick layer or fine silt on it, the area where injectors go into the head, the EGR vacuum solenoid, the valley cover on the engine was over an inch thick of silt.
Thanks for the speedy replies, off to get a part ....
