- Mar 14, 2013
- Reaction score
- 75
- Location
- Texas
- Make / Model
- Ford
- Engine Type
- 4.0 V6
- Engine Size
- 4.0L SOHC
- Automatic
- 2WD / 4WD
- 2WD
- Tire Size
- 31
- My credo
- I need more sleep.
I have an OBD 2 scanner I was checking for fault codes and P0297 came up and I looked it up and it says its an overspeed condition? Am I driving to fast or something? Any help with this, and if it's a serious problem or not... And how to fix it.
I've also got a U1900 Network code and B1352 Body code..?
Everything seems to work fine....
Oh and I did some more digging into the P0297 code and found out that it's because I went over 95mph, I hit 97mph last week. I don't think anythings messed up because there no check engine light or anything and it runs just fine. As for the other codes I can't really find out what they are other than a small description.
I just hope my trucks not broken. D:
I did some looking up on the B1352 and U1900 code, and it seems that the B1352 code is for when you have the key in and the door open the chime plays, and my chime still works so I guess it might be that I have all those extra lights wired up and its messing with it. Not really concerned about it I can live without the buzzer.
U1900 is still in the dark I can't figure out what it is!
I should try clearing them and maybe lay off the dirt racing.....
