Partial rebuild question.
4.0blue98
I don't feel tardy...
705
Frederick, Maryland
4.0 OHV
Round
It was like that when I found it.
Can't seem to find my specific situation address on the internet. I've tried all sorts of searches but no luck.
Did a budget rebuild on a 326 Pontiac with heads disassembled and cleaned, rings, bottle brush honing, new rod and main bearings, but didn't touch the cam or flat tappet hydraulic lifters. Relatively new and looked great. the bits (valves (cleaned and lapped too), valve springs, pistons, lifters, push rods etc) were placed back in their original correct location.
Question is: what type of break-in would be appropriate? I have 10w40 Motul break-in oil in there now and have for 10 or 11 full temp heat cycles. When should I change the oil to the zinc containing regular flat tappet oil (I have 10w30 VR1 ready to go)?
All I see is immediate oil change after cam break-in and then mile increments. I believe the rings seated since no blowby and no smoke out the back, but really haven't run it under much load.
gaz
679
Wa, Bremerton 98310
Ranger 5" (1½" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 33"/3:73LS
@4.0blue98 ,
To seat the rings I would, in the driveway in PARK:
• warm up to normal operating temperature
• then slowly spool up the engine to 2,000 RPM, moderating the RPM up and down +/-300 RPM slowly from 2k to 2,300 RPM to 1,700 RPM back to 2k and repeat, for 20 minutes
• change the oil
DONE
scotts90ranger
4,505
Dayton Oregon
2.3 Turbo
You're done, change the oil and operate as normal, everything special is for flat tappet cam berakin, rings will mostly figure themselves out on a hone and rering in short order assuming standard iron rings not molly rings...
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,590
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
While not scientific... I say change it and put some miles on it.
4.0blue98
705
Frederick, Maryland
4.0 OHV
Round
This all sounds good to me. I've probably done the rpm variation while setting the timing and fiddling with the carb. Just put a new master cylinder in last week so probably do that oil change next Saturday. Then I'll follow @Uncle Gump and drive it!
