Payload Package #2 and axle upgrade for towing
Wendsong
I am a novice at this and I know nothing about trucks, so bear with me, please.
My first '92 Ranger had the "Tow package", which I am assuming included the Payload Package #2 and the correct axle ratio. It was rated to tow 4500 lbs and I towed a 3500 lb Lance 5th wheel.
I now have the same truck, a '96 XLT supercab 4.0 V-6 4x2 Ranger with Automatic and Super Engine Cooling except I don't believe I have the Payload Package #2 (Tow package) or 3.55:1 axle ratio. I bought this Ranger new in 1996. From the door sticker, it appears that this Ranger can tow only 2700 lbs.
Can anyone tell me, specifically, what options were included in the Payload Package #2 and how can one determine if my Ranger has it? And, if not, can those options be installed after-market? Is it possible to change/upgrade the axle ratio?
Thank you for your time and patience.
8,370
GCWR, gross combined weight rating, is total weight of vehicle with passengers, cargo in the vehicle, and trailer with its cargo
1993 and up 4.0l Rangers had about a 9,000lbs GCRW
2WD Super cab Ranger weights about 3,500lbs, 4x4s weigh more so can tow LESS weight
So that leaves 5,500lbs for passengers and loads
The Ranger itself has a 4,900lbs vehicle rating so 1,400lbs is max weight in/on the vehicle, passengers and cargo
Yes the rear axle ratio is important but with an automatic trans you have more pulling power, automatic is simply stronger than a manual trans, and has infinite start up ratio in the torque converter, so getting heavier loads rolling is easier.
Generally 3.73 or 4.10 would be better ratios for towing.
Look at the door tag on your 1996, example here: http://www.therangerstation.com/how-to/axles/ford-7-5-8-8-inch-axle-tag-door-codes/
It will have GVWR, trucks max load at the top, doesn't include trailer, thats truck only
It will also have AXLE code to see what ratio you have.
You will have to see if you can find 1996 GCWR for your model
If your hitch is rated for it the 3,500lbs trailer should be fine for 4.0l Ranger
Trailer hitch also has a max weight rating, 2,000lbs(bumper) or 3,500lbs(below bumper) were the stock hitch ratings
Can you tow more?
Yes, really up to you on what you feel safe with, if you get pulled over and weighed, or there is an accident, is when the "legal" Weight Limits come into play.
Yes, you can add oil cooler, better trailer hitch and change rear ratio to make a better towing rig, that was the "towing package" Ford offered, I think rear springs and shocks were also different with tow package
Wendsong
Towing Package
In 1992, I bought a new Supercab Ranger with a 4.0L SEFI V-6 engine and a "Tow Package". I don't know what all was included, but it had an automatic, large a/c and 3.55 limited slip axle. It was rated to tow 4500 and I pulled a Lance 5th wheel, which Lance had designed specifically for the Ranger. The Lance dealer installed the hitch, the wiring and replaced the shocks with gas so the truck would be level for the trailer. It was beautiful to behold and to tow!
I now have a 96 Ranger. The VIN code says it will tow 2700. The sticker says it has a 3.55 limited slip axle, but does not list a "tow package". The Ranger Specifications book I have for 1996 lists the Styleside Maximum Trailer Weights for 4.0L SEFI V-6 Automatic with 3.55 Axle Ratio and 4 x 2 Super Cab as 5800 lbs. There is no mention of drum size, suspension, wiring or any other requirements.
I don't know which I should go with, the VIN code or the Specs.
Denisefwd93
74
South East PA
Do you still have the fifth wheel, if not does it really matter? You have the truck, you can make it into whatever you need; larger brakes, larger transmission cooler, extreme duty fan clutch, none of it's terribly expensive unless you blow the transmission!
No members online now.
