Look at the throttle cable at the gas pedal end, the cable stretches and you no longer have full throttle.
Google: Ranger throttle cable mod
very easy to do
As said above, no, larger injectors won't help stock engine.
Computer controlled engines meter fuel based on air flow(MAF sensor) and exhaust oxygen levels(O2 sensors)
So as long as your current injectors can supply a balanced 14.7:1 air:fuel mix at all RPMs then a larger injector doesn't change anything.
It isn't the same as putting larger Jets in a carb, but it is in some ways.
Putting larger jets in a carb would simply flood out the engine if they were too large.
But if adding a Cam to increase air flow was done then larger Jets could be used.
With Computer control the Cam will increase air flow and computer would see this, so automatically added more fuel to balance the mix, stock injectors would be fine since they can provide more than maximum required.
If you use forced air, like turbo or super chargers then you may need to change injectors depending on the boost(extra air) you will be forcing into the engine.
