Pic Request: Bronco II w/ 4" of lift and 31x10.50's......
mjonesjr
I dance with the Devil...
Firefighter
Forum Staff - Retired
13
Salem, IN
I am looking for pictures of a Bronco II with 4" of lit and 31x10.50x15 tires.....
anything will help...espically if the fenders are not cut...
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
3" of body lift and 31x10.50s is pretty close if this helps.
mjonesjr
Firefighter
13
Salem, IN
thanks that helps a ton.......
i also like your exhaust exit....i might have to do that to get rid of the 1 quarter size rust hole in the body...
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
Thanks. The body lift allowed me to run it between the frame and body so it doesn't hang down and get caught on stuff like my old tail pipe did.
Jorley
Crawfordville,Fla.
2.8 duraspark
No lift(yet) and 31x10.50's. Basically a stock '84. Maybe this will allow you to compare looks.
mjonesjr
Firefighter
13
Salem, IN
did you have to do any trimming with the 31's on the body lift?
Jorley
Crawfordville,Fla.
2.8 duraspark
No. The only rubbing I had was from a plastic trim piece that had come loose on the driver's side front. It was the trim that is below the bumper and wraps around, I reattached it and no problems.
mjonesjr
Firefighter
13
Salem, IN
looks like i am going to be getting some 31's here real soon!
are those 31x10.50x15's? what size wheel are you running? what back spacing?
Jorley
Crawfordville,Fla.
2.8 duraspark
Yeah,31x10.50x15 on the stock rims. I put them on before I found this site, so didn't know about backspacing or anything like that. Still not sure what it is. The tires give me about 9" of clearance at the rear diffy, which looks like the lowest part.
mjonesjr
Firefighter
13
Salem, IN
i might run 30x9.5x15's for a while with a 2" spacer up front....i don't really want to do a body lift after seeing a couple pictures with the bumper in the factory location....
Jorley
Crawfordville,Fla.
2.8 duraspark
The 10.50's don't stick out to much, so not to much gets throen up on the truck. They are pretty much even with the fender flare.
CJREX
8
N. GA.
2.3 EcoBoost
2.3
Here is my old '89 on 31x10.50s, 15x7 wheels
Explorer springs front and rear. No suspension lift (except that provided by the Explorer springs) and no body lift.
It only rubbed when off road.
spdcrazy
Homer, alaska
mostly 86
B2
2.9 bored and cammed
if you go for 30x9.5x15's on a stock suspension b2.. expect it to look like this
mjonesjr
Firefighter
13
Salem, IN
those wouldn't be bad with a 4" lift.....that would give the suspension room to travel...
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
I'd be looking for 4.10 axles if you want 31s, although yours is an auto so it might have them. Mine really sucked with 3.45 gears.
