pitman arm
Divh
bloomsburg PA
1949
hi i am trying to get my pitman arm off cuz putting 4in lift on truck i already broke my puller on it then tried a high grade bold and bent that anyone have any ideas even tried my air hammer
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
Pitman arms can be a huge PITA for sure (I just got done dealing with one myself).
A couple methods I've used to get them off (in addition to using QUALITY USA-made tools) is putting a goodly amount of tension on the tool, then beating the side of the arm next to the spline with a hammer to sortof "shock" it into slipping off. Another is rapidly heating the arm next to the spline with a propane torch on full-blast (being careful not to torch anything nearby such as the brake line that runs along the face of the crossmember) to coax it off via expansion. Relying on just a puller alone to get it off carries a pretty high risk of the tool breaking though (almost a guaranteed if it's a cheap imported puller, so it's well worth spending a bit more coin to have a good tool here).
Good luck with it.
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
I guess you are removing the pitman arm from the gearbox...probably similar to a ball joint removal...and as 4x4junkie suggested...heat and hammer...and it might even help to pull the gearbox completely and put it on a bench so you can hammer downwards on the arm after applying heat...
I recently pulled one from my 96 and was contemplating swapping the arms onto the manual gearbox because the original arm on the manual has about a 1" drop...fortunately, this worked out OK with mine without removing the pitman arm...
