Plenum gasket
Stranger ranger
so, i bought a upper intake plenum gasket tonight, for 9 bucks, felpro from advance auto. Only problem is, I received two gaskets, which are IDENTICAL, so do they just give you an extra, or would this be for the bottom of the fuel rail?
UrbanRedneckKid
17
Cass Co, Missouri
The one under the fuel rail is identical.
Though most of the time it is unnecessary to remove the fuel rail from the lower intake.
If you do leave the rail on the lower, make sure to check the torque on those bolts. It's easily overlooked and can leave you with a vacuum leak you didn't have before.
Stranger ranger
ya i figured as much, i'll torque them down. anyone know the torque specs of the upper bolts and the fuel rail e7 bolts?
UrbanRedneckKid
17
Cass Co, Missouri
Upper left-hand corner of the tech library, Click the link for the 4.0.
