PlumCrazy's Build
036speed
02/2013 OTOTM Winner
44
Akron Ohio
F-250
351
Solid Axle Swap 4x4
6"
Another thing we haven't factored in is the actual rolling diameter of a big, squishy tire at 7-10 psi..lol
Eh, its just like school. "Ignore gravity, ignore friction"
PlumCrazy
2014 Truck of The Year
177
Millersport, OH
Solid Axle Swap 4x4
Lol
Sent from my XT907 using CrapaTalk
1badexplorer
Firefighter
4
Sutersville Pa
3.0, 501, 7.3psd, 351c, 351w
Brad you could always do a 203/205 combo behind your ZF5. They are the same spline and will bolt up. You would just need teases and a doubler kit. Better low range, stronger, and you can still be 1:1 on the highway.
PlumCrazy
177
Millersport, OH
Solid Axle Swap 4x4
Moar goodies showed up today.
Tired of getting nasty looks from everyone at the park when I am wide open throttle..so decided to put a muffler back on. Used the have a Thrush 2.5" and loved it, its durable and has no packing to blow out. I am going to fix my joint where my stack connects too since every time it rains I end up with a half gal of water in the exhaust..
New pre cleaner bowl to replace my cracked, yellowed one that I tried to night shade a year ago...
I think I am going to powder coat the rest of the pre cleaner since it is started to surface rust
Picked up these from some guy for cheap. Should work and I will have extras.
escort_gts
02/2012 04/2013 04/2014 OTOTM Winner
16
Fort Wayne, IN
4.0, 5.0
I just painted my pre cleaner bowl.
Sent from my Rooted SM-N900T
PlumCrazy
177
Millersport, OH
Solid Axle Swap 4x4
I tried to tint it LIGHLY with night shade by applying it heavy and wet sanding it down to make it even, but it was a epic failure.. the paint caused the plastic to crack for some reason. I like the crystal clear look anyways.
escort_gts
16
Fort Wayne, IN
4.0, 5.0
Mine didn't stay clear long, maybe a few weeks before it turned yellow
PlumCrazy
177
Millersport, OH
Solid Axle Swap 4x4
Mine lasted for over a year. I bought it from the JD dealership last time. This one was an Ebay special...so it will probably be junk in month.lol
PlumCrazy
177
Millersport, OH
Solid Axle Swap 4x4
Not a whole lot going on with the truck, but I did decide to clean up the TSL wheels a bit.
Step 1...roll out of garage
Step 2...wash and reveal original color
Step 3... sand and lay a nice coat of white
Step 4...recoat with most obnoxious shade of yellow possible.
I also popped the outer beads off all my wheels and swapped the rubber stems out for the bolt in type. and finally got the piece of tree bark out of the bead.lol Its been in there for a year and it never leaked.lol
All four tires had a handful of sand in side too.lol Not sure how it got in there.lol
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
That's a fugly shade of yellow lol.
Shoulda just left them white.
PlumCrazy
177
Millersport, OH
Solid Axle Swap 4x4
wizkid00104
13
West Newton/Penn Hills, PA
2.3L/5.4L
Lmao. 1bad says hes trying to get you and Brad out to West Co next weekend. Are you?
PlumCrazy
177
Millersport, OH
Solid Axle Swap 4x4
IDK about next weekend.lol Im planning on SOR the weekend of May 9th.
88_Eddie
155
Raleigh, NC
2.9L, 4.0L
i have a gas RC car with the same color wheels lol
