Scored an auto condensate drain from work. Its setup for 1-45min intervals and 1-10 sec durations, catch is, it has 24V DC coil. So I picked up a cheap 2A power supply and opened up to add a longer cord and put the right plug on for the coil/timer. Its was a nice one...stainless housing and rated for 5000PSI, but the compressor at work sees 5500 when we are firing big sled pulses, and the coil wasn't strong enough to shut it back off if it tried to purge with pressure over 5K. Still perfectly fine for my intentions.
I added a switched 110V outlet and indicator light to the junction box on the compressor so I can disable the drain if I need to. I also added a muffler with a serviceable filter element. I am going to see how loud it is before I decide whether or not I need to vent it through the wall to outside.
I haven't tested it out just yet, that will be tonight's adventure.
Finished the furnace install and added a power indictor light to it as well. The garage isn't insulated really, so I don't want forget to turn it off and have it kick on and waste propane when I am not home.
Added an outlet above the work bench for a cord reel.
I also rearranged the breaker box so things are more split up and make sense. The garage used to run off one breaker from the house panel before we put the panel in the garage. I finally put a proper power cord on the welder that isn't coarse stranded scraps from who knows what.
My light fixtures should be here today or tomorrow...once they are up...its Ranger time.
