Made progress with the blue turd..I pulled the t cases out to assess the damage.
Found a large hole buy the rear bearing (knew that already)
Then saw a small hole buy the front sprocket (not surprised)
Then found 60% of the teeth from the front sprocket laying in the bottom…oops.
I was able to use a 1354E case half I picked up off 036speed to put the rear case together. I pulled the magnet off and tapped all the holes from the e-shift BS and put plugs in them. I also used the front sprocket and chain from the 54E case.
While I had the cases laying on the bench I pulled the doubler apart for the first time since install (20K ago). Looked perfect, but while I had it apart I went ahead and used the 6 gear planetary from the 54E case to upgrade the current the 4 gear. When putting the 6 gear in place of the 4…you have to swap the shift fork and collar as well (learned thisthe hard way when I upgraded the rear case a few years ago.lol). The front cover must also be used from the 54 case since the 1350 cover has a smaller seal bore diameter.
1350 seal on top. It’s a wee bit smaller.
Something else to note...Some early 1350 cases are 3/8 SAE for the 5 trans to case bolts where as the later ones are M10. If you are not careful...you will trash the front cover. The 3/8 bolts will fit into the M10 holes, but they will begin to cross thread after about 4-5 turns. (I found this out a few years ago...luckily I caught it before ruining anything). So I now have to go back to metric mounting bolts like original case had.lol
For those interested…and AWD (4404?) Exploder case has a 6 gear planetary, but uses a different main bearing and isn’t a direct swap for the 1350/54.
Oh…and progress on the Ranger will probably slow down even more now….(not quite shifted into reverse yet, but just slower in the forward direction) I picked up this little rice rocket yesterday to DD, so now I can focus more on the F150.
It has a lot of goodies. Not that many on this site care, but it is swapped to a 2000ish B16 and Si trans, has legit adjustable shock/coil overs all the way around, jet coated long tube header, tuned by a very reputable shop, lots of “JDM” goodies too. It has typical rusty quarters, but also came with a rust free donor car shell.
