Points style distributor
Aimwell
10
Louisiana
3" Body lift with lift springs on the front
31x10.50x15
Thanks for the info. I am going to try some "engine restore" to try and get my compression up. I found another motor I may rebuild before this one gives out
AndyB.
142
Cincinnati, OH
If you’re able to do so, a leak down test can be very helpful in this scenario. You can probably use the hose or spark plug adapter to connect to an air compressor and position the #1 cylinder at TDC. You’ll be able to hear air leaking out and it will help you determine if your loss is at the valves or rings.
Aimwell
10
Louisiana
31x10.50x15
Thank you for the heads up. I will try it and see. May save me some headache
Aimwell
10
Louisiana
31x10.50x15
Got it going. Upgraded to the pertronix and flamethrower coil and she's running. Tuning everything out now. I appreciate the help and info from everyone!
