por 15 or eastwood products?
racsan
4,443
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
Im about to start on the rear wheelwell repair of my ‘09 escape, plan on using either por-15 or something similar from eastwood products. Any recommendations from someone who has used both? I have used por-15 before, its great but if something else is better or just as good for the $. I plan on coating the rear underside before putting the trailer hitch on too, might even put 1/2 all-thread up into the body with 1” flat iron on the inside in the cargo area for more support.
Jim_Philly
6
Norristown (Philadelphia Area), PA
Ranger FX4 L2
If you can wait for the products to be back in stock, go with Mastercoat rust sealer and then AG-111 topcoat:
If you're wondering why they're out of stock, it's because they outperformed all other products, including Eastwood Rust Encapsulator Platinum and POR-15 by a huge margin in this video:
EDIT: I replaced the video link above, I had the wrong video.
I used Eastwood platinum on a floor pan prepared according to their instructions and rust spots bled through after a year.
Good luck!
