Post informative links here!
Pt_Ranger_V8
FullsizeFreakin'
U.S. Military - Active
Forum Staff - Retired
in ur g'rage, uzin' u're toolz
19 something
If you find a thread that has some good info, post it here. I'll add the relevant posts into this thread, and we'll keep a more up to date reference of swaps.
Mac
183
C. Wisconsin
2000
199
85_Ranger4x4
17,961
SW Iowa
ecablarn
Michigan, Bay County
Ford / Ranger
302 V8, Mild Frame off Restoration still have bodywork
Leveling 2" Lift
31x10.5xR15
BSME, design, drawing
For 93-94 rbv stock tachometer to v8 conversion - that works
http://www.therangerstation.com/foru...ad.php?t=73807
(will edit if it works with 92 as well) - "Should work" on 89-94 have same instrument cluster with 8cyl post on back of the cluster housing
repost this in the search for previous discussion:
therangerstation.com/forums/archive/index.php/t-73807
SAY789
6
Springfield Or
5.8L
Though id add a lil info. This is from my 351W swap in my 1994 Ranger. Using these headers on a 302 would work so much better
1990 Bronco shorty Flow Tech headers fit nicely. They are a ball flange as well so no gaskets at collectors.
Driverside needs one tube massaged a lil to clear shaft on the 351. Hugs block tight and aims down along C6 tranny with alot of room to easily mount exhaust.
Passenger side angles out above the frame rail. Im going to take a small pie cut to make running exhaust better but it could work without cutting it.
Pics are thumbnails linked to my photobucket
85_Ranger4x4
17,961
SW Iowa
The '88-92 "aluminum" slave uses the "black" coupler and the line used on all Ranger/Bronco2/Explorers up to the end of 1992.
in 1993 Ford switched to a glass reinforced plastic slave cylinder that
I believe is better than the earlier ones, but this requires a different
clutch line, one that uses a "gold" colored connector (they aren't compatible)
The later gold colored quick connectors are slightly larger than the older black ones. I read a post a while back on TRS where someone in this situation simply filed down the end of the gold quick disconnect to make it fit. I'm not recommending this method,but there it is for your consideration.
http://www.therangerstation.com/forums/showthread.php?t=171332&highlight=connector
http://www.therangerstation.com/forums/showthread.php?p=1607154#post1607154
