power steering pump O-RINGS
Angie
368
Vancouver area BC Canada
92 & 83 project
4.0L 302
Cleaned the pump base, took apart the housing for a color switch, off with the yellow one and on with a black one I had sitting on a different pump.
Clean and ready to go... Now I want to know if I can order the 3 O-Rings from ford for the pump?
There are 2 on the spring loaded fitting and one large one that seals the 2 piece body.
The pump number is RF-D8AC - 3D609-AB
Any info is great, thanks
Angie
368
92 & 83 project
4.0L 302
Just an update for anyone ever in the same spot.
Went to ford parts counter today after work. took the pump in with me. fellow looked over every spot on the data sheets (computer). Nope. They don't sell the o-rings. But will sell me a new pump... ARRRHGG was talking to another ford guy after the store. he suggested I take it to a hydrolic shop to see if they can carry the o-rings that are needed.
will update if I can get lucky finding the right ones. (or not)
Doofy
7
Alaska
Shit Happens...Then You Die.
I always got my o-rings at NAPA. If they didn't have what I needed, we could usually make one from a o-ring making kit they had. If there is a will, there is a way.
alwaysFlOoReD
5,121
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
The hydraulics shop, a bearing supply house, and industrial supply shop, any place like that will point you to the right place if they don't stock what you need.
AndyB.
142
Cincinnati, OH
You didn't list an application, but you can buy a seal kit for the pump for under $10.
