Price of Dana 35 axle shaft?
XionicWaste
April 2012 OTOTM Winner
19
Menomonie, WI
Solid Axle Swap 4x4
3"
37x12.50 Pitbull Rocker MTs
Custom everything! Purists look out!
So I broke an ear on my right side axle shaft and I called the junk yard and they told me 65 dollars per shaft. Whats the going price for a shaft?
AllanD
TRS Technical Staff
135
East-Central Pennsylvania
1987... sorta
'93 4.0
You need the inner or outer shaft?
I don't know what the going rate is but I have several spares...
And I'll sell it cheaper than that abusive price
AD
XionicWaste
19
Menomonie, WI
Solid Axle Swap 4x4
3"
I need the long right side shaft. It broke where it attaches to the outer u joint. I want a full set, left and right, for spares.
XionicWaste
19
Menomonie, WI
Solid Axle Swap 4x4
3"
Heres an image of what broke.
06RangerXLT
54
Georgetown Ontario
so you just need a new u joint?
XionicWaste
19
Menomonie, WI
Solid Axle Swap 4x4
3"
No the real damage is on the back side of the pic the u joint never broke, the shaft ear which holds the u joint broke.
06RangerXLT
54
Georgetown Ontario
ah. 65 for a shaft doesnt sound bad. offer him 50 and you'll come get it.
EDIT:
or SAS:headbang:
XionicWaste
19
Menomonie, WI
Solid Axle Swap 4x4
3"
Heres a better pic.
XionicWaste
19
Menomonie, WI
Solid Axle Swap 4x4
3"
Yeah a SAS would be nice, but not right now. The D35 isnt a bad axle, stronger than a 44 in retrospect, Im actually surprised I broke it.
06RangerXLT
54
Georgetown Ontario
i thought dana 35's were only good up to 33" tires. after that they are likely to break when offroad.
add 35's and 4.88 gears, SNAP
XionicWaste
19
Menomonie, WI
Solid Axle Swap 4x4
3"
Ive been running 35's for a few months now, 3 trips to Moab on top of local trails rating in excess of an 8/10 and not an issue till last night when I had the wheels cranked fully, flexed the truck out fully, and decided to keep climbing a rock. I thought a u joint would fail over the shaft end.
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
The HP D35 TTB is a fair bit stronger than the SLA IFS D35... 35s typically are safe to run on it, though like anything, it does have some limits lol
$40-70 seems about the going rate for shafts (inner + outer together) at full-service yards around my area it seems, though it's been a couple years since I've bought any.
Being that your axle ear broke and not the u-joint, I would suspect what likely happened is you lost the c-clip that retains the u-joint cap in the yoke, allowing the cap to walk out. The loose u-joint trunnion was then free to obliterate the axle yoke.
This can help put an end to lost caps:
http://www.therangerstation.com/Magazine/May06/dana35_ujoint_snapring.htm :icon_thumby:
crawlin91
60
Crawlorado
2.9, 4.0
if you need spare shafts I have a couple complete sets and a full set of brand new 5-760x ujoints and full circle clips (like in the article^) I would sell you for a fair price
XionicWaste
19
Menomonie, WI
Solid Axle Swap 4x4
3"
Yeah Crawlin 91 whats the price?
crawlin91
60
Crawlorado
2.9, 4.0
