problem with an 01 dodge ram
buell-eyed-devil
21
Wesley Chapel,Florida
FORD
5.0-ZF in process
3"body on new poly body mounts
Hey ya'll, watch this
bro-in-laws truck. been making a funny whining noise in rearend for a while. Well today his driveshaft comes out going down the road. Pinion nut came off. Went to push off the road and it wouldnt move. Hooked it to my truck, drivers rear rolled, passenger side was trying to go backwards. I broke a universal in my 86 Bronco, locked in the hubs and drove it home so I know this isnt normal. Any ideas?
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,552
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Ran it out of lube... and blew it up.
sheep herder
1,024
sheep pen
If it ain't broke, break it.
No lube=crunch and munch :eek:
8,372
+1 ^^^
Rear axle overheated and welded itself together
Pinion sheared off
Yes that is normal for rear wheels to turn in opposite directions, they do that if you jack up rear axle and spin one wheel the other turns in opposite condition, if its a OPEN differential
snoranger
Professional money waster
ASE Certified Tech
13,721
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
It probably has a seized pinion bearing.
buell-eyed-devil
21
FORD
5.0-ZF in process
popped cover off. no metal shavings at all. Looks like someone rebuilt rear end and didnt tighten pinion nut properly. Havent pulled completely apart but dont see any apparent damage
buell-eyed-devil
21
FORD
5.0-ZF in process
Update and new issue. Ring and pinion were good, installed new bearings and seals, had a buddy set up for me. Bolting everything back together and driveshaft yoke will not go inside transmission. cleaned splines up on both and lubed but shaft will on go in about 2" and locks up. splines on trans side look good...yoke hard to tell. Anyone had this problem before?
Dirtman
13,328
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Stick a pencil in the driveshsft yoke and see if theres a rock in it...
I still don't see how you could loose a pinion nut and have the driveshaft come free while driving and have no damage to anything.
ericbphoto
Overlander in development
16,733
Wellford, SC
3.0L
6"
At a minimum, there would be damage to my underwear.
buell-eyed-devil
21
FORD
5.0-ZF in process
couple races/bearings were junk but we replaced them
Dirtman
13,328
41N 75W
It's up there.
It's down there.
Round.
Well only reason the slip yoke wouldn't go on is if something is stuck in the hole or the internal yoke splines or external output shaft splines were damaged. I'd hope for a rock in the hole or at worst the slip yoke is busted because a bad output shaft means a total transmission tear down.
