wakingtowinter
- Apr 5, 2010
- 3
- Portland, OR
- Ford
- Engine Size
- 4.0
So I bought this ranger a couple weeks ago and the previous owner (99RangerKrazy on TRS, very nice guy) had installed the Stonecrusher steering setup. Getting it home (basically a 4 hour drive across WA) was not a big issue but there was a good deal of wandering and slop in the steering, which I thought nothing of because I have driven lifted trucks and obviously most lifted rigs tend to be a little sketchy on the street.
There was an issue when I refueled - pulling out of the gas station I took a right and the steering locked up (only way I can describe it) at full right lock and by the time I was able to stop it I had hopped up on the curb. Luckily it was midnight in a very small town and nobody was around and nothing was damaged. I was able to get it back on the road and I checked it out and realized that the saddle connecting the drag link and tie rod was dropping down and catching behind the passenger side axle drop bracket so that when I went to full right lock it would catch and not allow the wheels to straighten back out.
When I got home I adjusted and tightened the heim joints to try to correct this problem.
Here's a couple photos to illustrate this:
[URL=http://img816.imageshack.us/i/steering2.jpg/]
One thing I did was tighten up the heim joint connecting the tie rod and the saddle (making the end of the tie rod closer to the saddle). This seemed to limit the travel of the saddle so that it wouldn't catch on the drop bracket. I drove around the neighborhood a few times and went lock to lock enough that I was confident enough to drive it out in public, which I did without issue.
First question is - what the hell is going on here? I've heard good things about this setup and I know it shouldn't be doing this. I think I've solved the problem, but can anyone figure out what could be wrong and if I've actually solved it or not? I'm a little paranoid about running someone over and ending up in prison for vehicular manslaughter...
Second question - what's the deal with aligning the truck with this setup? I went to a tire place to get it aligned and they said they would only be able to adjust camber for both sides and toe on one side I think. They said to fully adjust it you would have to reweld the saddle on the drag link for a different angle. Isn't that what the adjustable heim joints are for? I really want to get this issue figured out because the tires are almost brand new and I would hate to mess them up because I can't align the truck. Thanks guys.
