Cooling fan from LMC bit the dust. I measured the resistance through the motor and was getting some near 0.3 ohms. If you work the math out, that means it pulls about 40 amps when it turns on which easily blows the fuse....
All the local parts stores had 12" and 16" fans in stock, so I just ordered one from Advance Auto. All said and done it was half the cost of the one from LMC. THe interesting part is that the LMC fan was made in China.... the Advance Fan (at least the blades) are made in the USA....
I checked the resistance in the new fan and it was a much better number at 5.2 ohms. The only things I had to do were flip the fan blade to switch it from a pusher to a puller and I soldered the connector from the old fan on to make it easy to remove. So far it works great. The last fan worked for 11 months... how long will this one survive?
New Hayden Imperial fan is on the left.
Fan Specs are here.
Test drove it with my co-pilot and he thought it worked well.
I looked at doing the knuckle upgrade and I decided against it. All of the brake components for the twin piston are twice as much and I really have no need for it at the moment.
On its way to me are re-manufactured front calipers, Powerstop brake pads, new rotors, Autolite Platinum spark plugs, new thermostat, water outlet neck, water pump, and upper radiator hose. Going to get all that installed and get my alignment sorted out then it will be time for some new shoes.
I can get a floor pan of Nick hopefully. If not, I will order one of those too.
I might actually get some time to get things done this weekend... we will see.
