Small update....
Wife's car got fog lights, snow tires, and new rear brake shoes installed. She is set for the winter.
The broken Ranger leaf is causing the truck to sag more and more. Last night I finally had some time to tear on of the "new" Explorer springs apart and get all the right pieces. I had to order the front bushings online, but a local spring shop has everything else that I can pick up tomorrow. I ordered U-bolts from Ruff Stuff Specialties and they are BEEFY. Also got a quart of Slip Plate to coat the springs.
When I bought them:
Center bolt cut off:
Leafs had steel isolators between them:
Here is what was left of the slider pads:
Here is the whole thing disassembled:
Now that one is apart, I have the rest of the parts ordered. I might tear the other one apart tonight. When it warms up Saturday or Sunday, I am going to sand blast the leafs and then sand them a bit to smooth them out before applying Slip Plate. Might be able to get them installed over the Christmas weekend.
For anyone who cares of the details, these springs are off a 97 Explorer. I ordered bushing kit Energy Suspension 4.2124G. This is suppose to fit 95-01 Explorer springs. There is one minor detail missing though.... the front spring bushings have a steel sleeve that mush be reused. As you can see, I do not have that luxury...
The correct steel encased rubber bushing is part # RB12ST from
www.autoandtrucksprings.com. I am putting this info here because it took some work. Direct linky:
http://www.autoandtrucksprings.com/products/Ford_Rubber_Encased_Bushing-2186-186.html
The rear bushings are much more common and the Energy ones fit perfectly, but I am returning the whole kit since the front are no use to me. Here is the rear:
So for anyone who needs the info, 95-01 Explorer leaf springs have a 1.875" I.D. on the front spring eye and 1.250" I.D. on the rear spring eye. The center bolt for the leaf pack is 7/16". Hopefully this will save someone else the time and effort
