Project: Twin Screw
hoosier1104
I'm Awesome!
MTOTM Winner
104
Camby, IN
302 based goodness
Work hard and play harder
Well after looking at the interior thread this morning, it is time for me to add a few custom touches of my own to the ST. Going to add around 6 different gauges to the radio bezel/center console and adding a push button starter.
Already started sourcing parts.
hoosier1104
I'm Awesome!
MTOTM Winner
104
Camby, IN
302 based goodness
UPDATE:
Since I have the SC and injectors already, I am going to build a SC based 347 stroker with a goal of 550-600 hp through a 4R70W trans and 4405 transfer case. Maybe a 4" suspension lift is in order as well. :icon_confused: :icon_idea: :shok:
This is going to be EPIC!
dangerranger83
5.0 HO under the hood!!!
54
Lafayette, IN
5.0 HO carbed with an np435 and np208
Aren't the 5.0 only safe to have 550hp max at the crank (unless you go with an aftermarket block)? I would do a 331 rather then 347 to help keep piston slap and wear on the skirts to a minimum.
hoosier1104
I'm Awesome!
MTOTM Winner
104
Camby, IN
302 based goodness
UPDATE:
Here is the list of projects that are going to happen.
  1. Tube bumpers (Front and Rear)
  2. Bedline the entire truck
  3. F350 Super Duty SAS w/ 4" lift(This fall)
  4. TT 4BT swap w/ auto trans and AWD
The truck is paid for and I plan on keep it for a long time so why not make it the way I want it. :icon_idea: :D :headbang:
dangerranger83
54
Lafayette, IN
Auto trans isn't a mans trans.
Ever look into the Kubota diesel swap?
hoosier1104
I'm Awesome!
MTOTM Winner
104
Camby, IN
302 based goodness
That is on the table. Rick is the one doing the work.
Going with a 4BT ISB w/ auto trans bc the wife may have to drive it from time to time and she cannot drive a manual trans.
dangerranger83
54
Lafayette, IN
Rick better be good at taking pictures.
When did you get married? I'm getting hitched next Monday.
hoosier1104
I'm Awesome!
MTOTM Winner
104
Camby, IN
302 based goodness
Not official yet; Sept of this year. I am getting something else as my DD as well.
hoosier1104
I'm Awesome!
MTOTM Winner
104
Camby, IN
302 based goodness
He is also doing my SAS as well.
hoosier1104
I'm Awesome!
MTOTM Winner
104
Camby, IN
302 based goodness
UPDATE:
This has been put on permanent hold. I have a fuel pump issue that needs to be addressed among other things. The good thing is I have a 98-00 Ranger extended cab coming to me. That is all the info I have on it as of right now.
The Ranger will only get comestic mods. NO MOTOR SWAP IS ON THE TABLE AT THIS TIME. There may be one in the future but that is a long way off.
dangerranger83
54
Lafayette, IN
Yaaaaaa another ranger!!
Your favorite window licker approves!
hoosier1104
I'm Awesome!
MTOTM Winner
104
Camby, IN
302 based goodness
I knew you would Bryan.
hoosier1104
I'm Awesome!
MTOTM Winner
104
Camby, IN
302 based goodness
