Proper install order.
Fryedbm
41
Ks
So as you know I'm about to tackle that front end. Obviously I got the bellows inner and outer tie rods however with the upper control arms and sway links. What is the best order to do this?
I hope that made sense.....
ericbphoto
Overlander in development
16,729
Wellford, SC
6"
I would get the front of the truck jacked up with the frame resting on Jack stands. Remove the wheels. Take pictures of how everything looks before you start. Measure the total distance from one steering knuckle to the other. Disconnect the anti-sway bar. Then remove the tie rod end on one side. Then remove and replace the control arm on that side. Install the new tie rod end on that side. Repeat for the other side. Adjust the tie rod ends evenly so that the distance from one steering knuckle to the other is the same as when you started. Reconnect the anti-sway bar using the new bushings or links. Double check that everything is tight. Put the wheels back on. Put the truck back on the ground. Carefully drive it to the alignment shop for an alignment.
Fryedbm
41
Ks
What would the advantage be of measuring vs counting threads?
ericbphoto
16,729
Wellford, SC
6"
If the new tie rod ends are made a little bit differently, ie; shorter or longer, that would throw off the overall length.
Fryedbm
41
Ks
Ok. Makes sense. Now the pics? What is the main idea to capture there?
Dirtman
13,328
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
In case you forget how something goes back together you can look at the pics you took before you started. :icon_idea:
Fryedbm
41
Ks
Ok. I will do that.☜ ᕙ(@°▽°@)ᕗ
ericbphoto
16,729
Wellford, SC
6"
ᕙ(@°▽°@)ᕗ
People with Jeeps type something like this in their posts. Is that what the grill on your truck looks like?
;missingteeth;
Dirtman
13,328
41N 75W
It's up there.
It's down there.
Round.
I thought it was an owl? :dunno:
Fryedbm
41
Ks
;missingteeth;
It is flexing.
So I am just rounding the inner tie rod trying to get the end off. Ideas?
Dirtman
13,328
41N 75W
It's up there.
It's down there.
Round.
Do you have the proper inner tie rod tool?
Fryedbm
41
Ks
I am using 2 wrenches. I thought the inner tool was for once I got the end off. But I am replacing the inner so I can just try to take off the inner with the end attached correct? I am also replacing the bellow as well
ericbphoto
16,729
Wellford, SC
6"
