Proz07's Black Pearl build
87turbostranger
New braunfels, Texas
Wow man nice build. You've done one hell of a job building this truck. I'm just north of you in new braunfels. It'd be badass to see this truck and some of the car/truck meets in NB or SA. I've got an 87 ranger i just did a 2.3 turbo swap in. Not nearly as powerful and wild as yours that's for sure! Lol but it would be cool to see it in person sometime if you're ever at any of the meets or shows!
proz07
11
TX
5.3l
Thanks, Unless its a dyno day or T&T at Alamo City Motorplex I dont go to "meets" around here. Ill just say those arent my scene.
87turbostranger
I can understand that, the ones in NB get pretty childish (most of them get shut down quickly now a days) and the ones in SA aren't terrible but seem to be aimed at the guys with cars and big wheels most of the time. Maybe once the new year starts and everything settles down they'll be more real shows and dyno days.
proz07
11
TX
5.3l
Post dyno I finally found nice enough weather to finish the AC... but turned into a rewire as well with a spare harness i had laying around. The fuse panel from 88 has seen better days. relocated the ECU a little and some additional wiring switches, interior lights etc.
20200906_101300 by Z S, on Flickr
20200907_114904 by Z S, on Flickr
20200912_134232 by Z S, on Flickr
20200917_202335 by Z S, on Flickr
Center dash panel and rear where i added a few relays to run some traction control and line lock inputs to the ecu.
20200927_152626 by Z S, on Flickr
20201003_174130 by Z S, on Flickr
Built an adjustable clutch switch for launch and flat shift when i get around to programming it in to the ecu.
20201015_200255 by Z S, on Flickr
Didnt get a finished pic but was able to add a reluctor ring to the front with a mustang ABS sensor to start playing with traction control.
20201017_170212 by Z S, on Flickr
Finally added the LMC dash cover and re flocked the cubby. looks great honestly if you paint the trimmed out areas on the dash prior to install.
20201018_192819 by Z S, on Flickr
20201018_193153 by Z S, on Flickr
20201023_144022 by Z S, on Flickr
Dash installed but still need to redo the gauge panel and then flock it black.
20201105_183006 by Z S, on Flickr
Added LED interior lights... probably the best thing since getting this truck going. You dont realize how much a pain it is till you dont have an interior light at night.
20201105_183012 by Z S, on Flickr
Also recovered the headliner although a little brighter than i wanted i think itll be fine once i do the door cards the same and then black carpet.
20201111_131644 by Z S, on Flickr
Another nicety, underhood lighting.
20201104_202227 by Z S, on Flickr
And quick finished up running of the AC/Heat lines, and works pretty good so far. we will see when its 110 out though.
20201101_133951 by Z S, on Flickr
20201101_134009 by Z S, on Flickr
20201101_133959 by Z S, on Flickr
20201101_134027 by Z S, on Flickr
proz07
11
TX
5.3l
Harnesses all cleaned up and and relocated ecu, sealed up all the firewall holes as well.
20201101_134021 by Z S, on Flickr
20201101_154002 by Z S, on Flickr
Looks like its gonna be nice come summer!
20201101_155144 by Z S, on Flickr
After that and looking at data the last dyno session we floated the valves so installed some billet rocker stands and dual .660 springs.
20201114_110910 by Z S, on Flickr
20201114_143432 by Z S, on Flickr
20201114_143732 by Z S, on Flickr
Checked plugs and compression while we did that, still burning about 1qt oil over 1500ish miles... itll work for the JY motor that it is, lol.
20201114_183447 by Z S, on Flickr
Then we hit up a Toys for Tots dyno day to validate the spring change. 836 wheel at 27# so more power at less boost is a good indication we fixed that problem! now to start dialing in the traction control, launch, flat shift, boost by speed, etc.. maybe even work on the interior a bit more.
20201219_174122 by Z S, on Flickr
20201219_210420 by Z S, on Flickr
And video... needed some extra weight since it just blew the tires off without....
20201219_175709 by Z S, on Flickr
Its build season folks get on it!!!!
-Z
