putting together Dweano's front end (D35)
-Nathan-
39
Saskatoon, SK, Canada
HO 5.0 / 7.3 PSD
Well, long story short, I had regeared Dweanos truck, well the rear axle at least, to 4.56. I hadnt had time until now, so I have his truck in my shop. Its easier if I just post up pics here, than try and email them all individually lol.
So took the wheels off, took the hubs off, took the caliper/rotors off...this is what I found:
that is why you torque the outer nut to 250 ft lbs, so they DONT do this, Hes just lucky I found it like this before something bad happened.
removed spindles, and took out axleshafts
the drivers side shock mount had broken, so Dweano had this as a temporary fix
I couldnt let the truck leave my shop like that, so I cut it apart, and cut a bolt up.
welded it in place
and ground smooth, much better haha.
the u joints were shot in the axleshafts
so I put new 5-760x joints in all 3 joints
and clearenced the slip so it wouldnt bind as easy
and did an E-clip eliminator
and painted the shafts
front diff was full of water haha, time for breather extensions eh buddy!
pulled the pig, and pulled the carrier and pinion
removed all the old seals and bearings
cleaned up the pig, and shot a coat of paint
and painted the beams
tomorrow Ill set up the new gears in the pig, and maybe start to put it back together.
Dweano
Saskatchewan!
Wow. First off...I would like to say. Hi everyone...my name is Dweano...and I approve this thread.
Second: Nathan you are a machine. This amount of work would have taken me like...a week and I just dropped it off yesterday. Haha
Third...that bungie cord held my shock on good!! hahaha
Fourth...wow my front end is a piece...everything was falling apart. Thank goodness for these upgrades!
Fifth..Breather hose extension will happen (actually I have a piece of hose in my cup holder thing just for that...I just remembered. I was going to do that but then I figured I would wait until I have all this done haha
strvger
19
the land of 2 seasons-Winter and getting ready for
2.3
i think Dweano is very lucky for two reasons:
1st, that he hasn't had something really bad happen before he got it fixed and,
2nd, that he has Nathan for good friend.
yep, life is good to Dweano!
shane96ranger
221
Utah
Ford F150-Stang
4.6 Triton / 5.0
Very nice work Nathan. I concur, Dweano is lucky you're working on his rig. I need to do U-joints in mine, and this thread just reminded me. I have some 5-760x joints just waiting. I just need some time.
-Nathan-
39
HO 5.0 / 7.3 PSD
haha thanks guys, but Im not doing this for free, but am for a reasonable fee.
Brendan stopped by and gave me hand with the setup, always easier with 2 sets of hands holding shims/getting carrier into place.
Dweano had brought me a spare carrier that had a lockright in it...went to take out the locker, and the cross pin was WELDED in place, fought for the better part of an hour, but got it out...
this is why they say BE CAREFUL with the PLATE drop brackets...theres a ding in the pumpkin, its not through the housing, the housing is okay, but if it hits hard again it might destroy it.
got the carrier bearings changed
and after setup, put new seals, and pounded in the new pinion races, and new pinion seal
new pinion bearings, oil slinger
and setup
tomorrow Ill put the rest of the seals in the pig, and put it all back together.
peace.
Boggin
48
Good job nathan, when ya doin mine? haha
CHKNFKR
73
Illinois
545 CID
Wanna set up my rocks?
-Nathan-
39
HO 5.0 / 7.3 PSD
haha if you guys werent all so far away Id be willing to give you a hand.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
i try not paint shitty shafts without sand/soda blasting first...
better off wire wheeling with a grinder and dipping/soaking in urethane if you cant blast.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
add a drain too...they like to fill up with water even with the breather extended
brendank
It's only money...
Forum Staff - Retired
Saskatoon, Saskatchewan
I usually just left my D35 shafts unpainted, cause I knew they were probably going to snap the next time I went out wheeling anyways. :thefinger:
Dweano
Saskatchewan!
What kind of idiot welds that in. Thats what I want to know. The same one that sends a diff out with a chipped ring gear...thats what. Haha. I am so glad you got it out tho. Locked and loaded!
Also is that pic of the metal chipping to the inside? Its not flaking off or anything? The pumpkin is still structurally sound? I think I will take that bracket off and grind it down maybe. But I guess if it just bumped up with the 4 inch lift...adding six inch lift coils should a lil right?
And yes everyone. I am super lucky to know Nathan...super nice guy and super knowledgeable as well. The quality of work is top notch and he is charging me less that what a shop would (shops would destroy my dwindling bank account). I recommend him to everyone. Haha. Also thanks to Brendan for helping out!
brendank
It's only money...
The pumpkin is fine. There's no risk of that chipping off inside.
But you should take care of that lift bracket. It's just a matter of time before it causes some real damage.
Dweano
Saskatchewan!
Yep I will try to do that asap. Also I will put a longer breather hose in so my diff doesn't fill up with water again haha. I need front end lessons...I know like nothing about bearings and spindles and...whatever else is in there
