Delete Radiator Brackets - 1st Gen.
Bronco648
102
Chicago-land, Illinois
XL
2.3
15"
I have an '85 RCLB and am in need of the two brackets that hold the radiator to the radiator support. I would assume that they're the same for 1983 thru 1992?
TIA
RumPunch
Law Enforcement
827
Walkerton Va 23177
Ford Bronco II
3"
31x10.50R15
Brackets at bottom?
RumPunch
Law Enforcement
827
Walkerton Va 23177
Ford Bronco II
3"
31x10.50R15
Bronco648
102
XL
2.3
15"
Apologies, I saw a picture in my Haynes manual that showed upper radiator brackets for a 2.8 Ranger. Apparently, not all Rangers came with this configuration. My radiator has ears, with vibration isolators, that are molded into the side tanks, at the top. So, I'm guessing your BII is the same.
Bronco648
102
XL
2.3
15"
Also looking for valve cover 'keepers', the little winged things that go under the valve cover bolts. I'm missing a corner one (there's two types; more-or-less straight and more-or-less 45*). I need a corner (45*) one but would take them all if sending one is a waste of time.
RumPunch
Law Enforcement
827
Walkerton Va 23177
Ford Bronco II
3"
31x10.50R15
Junk yard is your best friend for those. Have a few extra not a set
Bronco648
102
XL
2.3
15"
A few extra would be fine, if you want to part with them.
My issue with local junkyards is that they have nothing that's older than 20-25 years. Most older vehicles have been crushed because they've rusted out and been (mostly) stripped. They need to make room for more 'modern' stuff.
RumPunch
Law Enforcement
827
Walkerton Va 23177
Ford Bronco II
3"
31x10.50R15
Let me see if I can get by the local pick and pay and grab enough for a set. I need a t-case bracket anyway
Bronco648
102
XL
2.3
15"
That would be great, thanks. I'm only missing one keeper; a corner. But, having a full set would be awesome.
