RedwoodRanger
- Jun 30, 2017
- 0
- Northern California
- Ford
- Engine Size
- 4.0L
Hi guys,
I'm almost done installing my 4 inch skyjacker class 2 lift on my 4x4 92 ranger.
Yesterday I spent awhile grinding my axle on drivers side (Dana 35) to accommodate the new radius arm. Anyway, my issue is after I bolted them to the axle then torqued the arms to the axle and then dropped the axles low with the jack to put on the coils and install the new bump stops the plastic spacer that goes between the new bushings and behind the new radius arm bracket (original ford part) broke. This happened on both sides I realize that it's weak point when the axle drops, but wouldn't this happen anyway in full droop when wheeling?
I'm going to the pick n pull tomorrow and should be able to get new ones(parts store doesn't have them) my question is has anyone else had this issue?
Thanks in advance!
Thanks in advance!
