ran into somethin I didn't see coming. .swapping to 10" brakes
PetesPonies
25
east coast
2.3l
I got a set of 10" rear drum backing plates. BUT . . the mounting is much wider than my Ranger housing. So . did Ford have a large bearing rear for Explorers? That is what these were supposed to have come off of. They are 10" x 2 1/2". I thought maybe a full size Ford truck, but they are 10", not 11". Anyone help with some info?
PetesPonies
25
east coast
2.3l
So . I'm thinking maybe it was from a 31 spline rear, bigger bearing? Can anyone confirm?
stegomon
20
auburn/minot maine
fords and only
That I know of you need the backers and drums from a 7.5
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Yes, 31 spline have a bigger mounting spacing for the backing plates.
And the end bearings are bigger in the 31 spline. If you take a good look at the axle tubes the 28 spline version necks down towards the end where the 31 keeps the same diameter all the way out.
PetesPonies
25
east coast
2.3l
I didn't realize the drum brake Explorers used a big axle as well. Oh well, time to switch for the right ones. Thanks
Sasquatch_Ryda
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Yeup you need them off a ranger.
