Rangebe...version 2.0
PlumCrazy
2014 Truck of The Year
177
Millersport, OH
Solid Axle Swap 4x4
It may be faster yet if I wasn't running HB brakes or if I had my unit ported.
Sent from XT907 using Crapatalk
-Nathan-
39
Saskatoon, SK, Canada
HO 5.0 / 7.3 PSD
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
When my new axles go in, I plan to pull my power steering pump and put in a hydraulic pump. I think it'll be cheaper and easier to go that route, won't have to worry about porting the pump or upping the pressure...
SVT
PlumCrazy
177
Millersport, OH
Solid Axle Swap 4x4
That's the same specs as my cyl...just marked up 200% to add a PSC logo.
PlumCrazy
177
Millersport, OH
Solid Axle Swap 4x4
The Saginaw can handle hydro assist and brakes no problem. Not to mention they are cheap at any parts store if you toast one on the trail and want to wheel the next day.
PlumCrazy
177
Millersport, OH
Solid Axle Swap 4x4
I wouldn't swap to a true hydro pump unless you are going full hydro on both axles
-Nathan-
39
HO 5.0 / 7.3 PSD
Thanks boys.
A few more things done.
Got the passenger bump can mounted, and strike pad welded in.
Grease zerks added to my swinger, the holes pass through past the delrin, and lubricate passages between the delrin/sleeve.
And got the passenger side tie rod made. I got everything to cycle perfectly with clearance with the heim on TOP of knuckle arm. I tried running it below and got bind.
Cheers.
wizkid00104
13
West Newton/Penn Hills, PA
2.3L/5.4L
Looks fantastic Nathan. Hope Santa brings your more parts and progress! :beer:
-Nathan-
39
HO 5.0 / 7.3 PSD
Got my fuel cell, and through it in place, havent made mounts yet. 32 gallon...
96firephoenix
Indianapolis, IN
I didn't see if you said one way or the other... you planning to put the outer skin of the bed back on for appearance's sake?
looks good btw! we can only aspire to your level of greatness
-Nathan-
39
HO 5.0 / 7.3 PSD
Yeah, I have fibreglass fenders for the truck front/rear.
Josh40601
MTOTM Winner
12
San Diego
Thanks boys.
Cheers.
Just wondering, why didn't you plate the frame there?
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
Didn't need it, its just holding a pivot point, there's no force being applied in this area...
SVT
kris97ranger
36
lisle ontario
4 litre and 7.3 litre
-Nathan-
39
HO 5.0 / 7.3 PSD
Hey guys, moved this summer so have been setting up the new shop. There will be lots of updates to come, as I have a couple shelves full of parts for this thing. Stay tuned!
