Ranger 4x4 2005 WL-T engine stalls when release clutch pedal
Bengus
Sweden
Hello!
I have a Ranger 4x4 2005 with WL-T diesel engine. If i press down the clutch pedal, transmission in neutral, I can start the engine and rev it up. The idle is fine. But if I release the clutch pedal the engine will go rough and stall. If i press the clutch pedal only just a little bit the engine will idle normal. If i put in first gear or reverse I can drive away when i release the clutch pedal but the engine will go rough and the engine will not rev up even if I push the gas pedal to the bottom. But if I just push the clutch pedal down a little bit it the engine will act like normal.
Any suggestions what the problem could be?
Thanks!
Bengus
sgtsandman
Aircraft Fuel Tank Diver
12,749
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Hello!
Thanks!
Bengus
We are predominately a North American forum for the Ranger but someone on here may be able to suggest troubleshooting and some tips.
