Rear Axle swap compartibility?
NIGERIAN RANGER
28
Lagos, Nigeria
Hi everyome. Being long time.
A friend is offering me to buy the entire differential/azle of off a Chevvy Tahoe hybrid, that has being sitting in his yard for some time now.
The rear differential of axle of the Tahoe is not electric though.
I am lioking at one day, replacing the entirety of mine, because it is making terrible grinding noise at the rear.
Is it possible to swap in the entire axle system with frw modufications to it?
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,543
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Anything is possible...
It would take a bunch of modifications...
Spring perches
Shock mounts
Driveshaft
Brake lines/park brake cables
Sway bar mounts
The first thing to do is figure out if the gear ratio works for you. Also measure the overall width... that Tahoe axle is going to be substantially wider.
00t444e
217
Southern OH
Ranger ext cab
I wouldn't bother with it, that axle would be a GM 8.5 10 bolt which is junk, and has a different lug patter as well. The Ford 8.8 is a far better axle.
NIGERIAN RANGER
28
Lagos, Nigeria
Thanks everyone, I am ditching that idea already.
