- Aug 7, 2007
- 540
- Costa Mesa, CA
- Ford
- Engine Type
- 4.0 V6
- Engine Size
- 4.0 SOHC
- 2WD / 4WD
- 4WD
- Tire Size
- 33"
Recently, I have been noticing a kind of hum or weird vibration at speeds above 55 mph or so. I checked out the drive train and the only thing I found was a slight looseness in the rear driveshaft slip joint. It is not loose in up and down movement but there is a rotational looseness. It is not a lot, but I don't recall any play before. I know there is backlash in the differential and transmission, I don't think there should be any in the slip joint.
Is this normal? Could that possibly cause the hum?
I am thinking the only repair would be to replace the entire driveshaft. Does anyone have any other ideas on this?
