FlyinRyan
- Feb 1, 2011
- 0
- Nova Scotia, Canada
- Mazda
- Engine Size
- 2.5L
Hey folks,
I've been working on my rear drums for quite some time now and have run into a few problems.
Truck: 1998 B2500, 2WD.
A few months back I started getting a heavy grating noise from the rear, so I popped off the drums on the rears and had a few pieces of metal fall out. Later determined they were the adjusting cable and the wheel cylinder to shoe pusher.
I was short on time so I replaced shoes and drums and ordered the part in from Mazda. I put my brakes back together, all new hardware. This time however, there was only one pusher coming from the driverside wheel cylinder. I figured this was okay, at least one of the shoes would push out.
Today I had the time to replace the wheel cylinders. I take the drum off of the drivers side to see what looks like perfectly new shoes covered in a black/dark brown slime. The slime is viscous. It looks like the shoes haven't made contact with the drum!
The passenger side didn't have this slime, and they have worn.
I didn't end up replacing anything because I couldn't get the brake lines off the cylinder without bending the lines. I know this is bad, and I don't want to replace the lines today.
Two questions:
-Has anyone seen this slime, or know where it comes from? I pumped the brakes with the drums off and it didn't look like any fluid pumped out of the wheel cylinder where the missing pusher is supposed to go.
-How can I get a stuck on brake line off of a wheel cylinder? I've tried penetrating oils and I can get the nut to move, but it's moving the brake line too. I've also put heat to the nut, then cold water, but it didn't do anything. How hot can I heat the nut without damaging the line or fluid? Any other tested solutions?
Thanks!
Two questions:
Thanks!
