Rear end conversion?
franky1205
Florida
SPLASH
I’m interested in having disc brakes in the rear as opposed to these drums I found one from an explorer and a mustang with a 5.0 which I plan on putting in in the future I believe it’s an 8.8 rear end do I have to have the motor and tranny from these cars in my ranger in order to have that rear end any tips and tricks would be appreciated
rusty ol ranger
2.9 Mafia-Don
7,837
Michigan
177 CID
No. Your engine and trans will spin that rear just fine.
The explorer disc brake conversion is pretty popular and well documented. Dont use the mustang rear.
Also, if you have 4wd you will need to make sure the rear you put in has the same gear ratio in order to match the front.
Welcome to TRS!
franky1205
Florida
SPLASH
No mine is a RWD drive so i have to find an 8.8 from an explorer ?
rusty ol ranger
2.9 Mafia-Don
7,837
Michigan
177 CID
That would be eaisest.
Why dont you post your question in the axle forum. Where youll get much better responses then i can give.
franky1205
Florida
SPLASH
Ok thanx I’m new to this site so thanx for the advice I’ll definitely do that
RangerFabWorks
The O.G blackwidow67
716
Lexington, North Carolina
302
Ill just move this to the axle section.
Welcome!
3,615
Use the Explorer rear end. Neither one is bolt-in, unless you want to loose about 4 inches of height off the rear of your truck, but the Explorer rear is going to be a lot less hassle.
The brakes are bigger, and better, and the parking brake hook up will be nearly 100% factory.
4x4junkie
585
So. Calif (SFV)
2.9L V6
35x12.50R15
The Explorer axle seems the most popular swap for those also looking for a strength upgrade at the same time (say, if you're running 35" or taller tires and/or a well-built engine). It isn't quite bolt-in though, you have to reposition the leaf spring perches and add shock brackets, which isn't a difficult job for someone with fabricating experience. However if you also lack a welder, you might consider having an off-road fabrication shop do the swap.
Some info on it here:
Another option if you don't need the strength increase but only want the disc brakes might be to look for a 2010 or 2011 Ranger 8.8" axle. I do believe these would be a bolt-in swap to yours (excepting for the brake connections) You'll need the u-bolts and leaf spring plates from the truck the axle comes from since the tubes are bigger.
Mike Tonon
Guest
Now, in theory, we could have 4.10 up front and 3.73 in the back and just run bigger tires up front and smaller tires in the back, right? If we want to be a cool kid?
  • Like
Reactions: Mac
18,061
SW Iowa
That is how they do it with tractors, although they usually have the front spinning a hair faster than the rear.
turbo91xlt
63
Goshen, NY
1992
My STX at the moment lmao, soon Ill get around to getting the FX4 Lvl II rear axle swapped in. But the transfer case survived all winter the very few limited times I HAD to use 4wd...
Speaking of, if the OP could find a Lvl II axle then he would have a bolt in axle with the strength of an explorer 8.8 and could easily retrofit the explorer discs to it. The only down side would be they only come 4.10 gears if thats not what he wants and replacement axle shafts may be hard to source if the need ever arose... wish Ford would have just used an explorer housing for the Lvl II for that very reason lol
pjtoledo
3,054
Toledo Ohio
Fords
3.0 2.3
there does seem to be confusion about the Level II axle shafts, do you know any part #s for them? and their respective lengths?
to the OP,, 2010 Ranger rear axles come standard with rear disc brakes. they are sort of a hybrid axle, Explorer style big axle bearings but only 28 splines in the differential. parking brake is the hat style. Unfortunately THEY DO NOT HAVE PROVISIONS FOR THE SPEED SENSOR ON THE DIFFERENTAIL
turbo91xlt
63
Goshen, NY
1992
I dont know the part numbers offhand but my understanding is it is the same width as any other '93+ ranger axle (~1.5" narrower then an explorer axle iirc) but 31 spline instead of 28.
Mac
183
C. Wisconsin
2000
199
