B Series
- Aug 9, 2012
- 0
- Mazda
- Engine Size
- 2.5
Tool Recommendations Needed
Lincoln 1142 Grease Gun with a rigid hose. Anyone use this grease gun? Price is right but can the rigid hose be replaced with a flex hose? Think the answer is yes, in any case ordered it will fill ball joints before installing.
2. I've been looking at IR231C Impact 1/2"Driver for $119. It uses 4.2 CFM min hose size is 3/8", 1/4" is recommended. I have a 2 gal., 100 PSI Campbell Compressor and wonder what are the Air Compressor specs required for this impact wrench.
I want the impact wrench for lug nuts, ball joint pressing, and whatever else comes up. I like this model because it has power adjustment and price seems pretty low.
Anyone look at the HOTECH Impact wrench? Looks exactly like the IR231C with similar specs for about $80 from ebay and amazon.
3. What are the electric Impact Driver alternatives?
4. What do I use to remove rust and prevent future rusting on the under carriage? Around Axles, Wheel Drum, Steering Knuckles, transmission etc?
5. Its really hot in texas so what do you use to protect rubber hoses, belts and alike? Thanks You Much
