Red Stepside build
Josh40601
MTOTM Winner
12
San Diego
The reason I say it's a beast is because of the reliability. These engines take a beating. It reminds me of the old 351W with less torque and greater mileage. You can best the living shit out of them and they keep on truckin. They may not be a powerhouse, but they hold up to abuse. I've cooked a 327, 350, 302, 4.0 (twice), and most recently an LS1. And I have respect for the 3L. That should tell you something.
3.0ranger1227
11
3.0L
I've seen the reliability. I drive the snot out of it. Maybe I'll just regear it to 4.88 or lower.
Josh40601
MTOTM Winner
12
San Diego
That will help. The suspension is ping to be awesome. I can't wait to see what you do with this thing!
3.0ranger1227
11
3.0L
It should be pretty slick - 35x12.5x15 grabbers, Method double standards(polished ring, I want polished center but they don't do that in the doubles - maybe ill get them powder coated red at some point), Burg LT w/ 2.0 hubs, SAW or red King C/Os up front. Glassworks 4"(maybe 6) up front and McNeil 4" stepside bedsides
Josh40601
MTOTM Winner
12
San Diego
Yes. Will be frickin awesome. I didnt know King was doing red now.
doyouquaxu
26
Orange County CA
King can do any color. They've got like 5 colors they can normally do, others are special order. Best looking combo I've seen is black bodies with gold annodized bits
3.0ranger1227
11
3.0L
So I'm thinking that around a 5.00 gear will be about right with 35s. Using the converter the correct ratio is 4.88, but I think by stepping it up a bit the truck will actually have some go. Plus the grabbers are heavy so the lower ratio should help. Thoughts on this? Will it be too much?
EDIT: looking at Yukon's site, they have a 5.12 set. With the amount of revs the 3.0 can do, it should be fine with that, right? And if I swapped over to a 5spd would it still be ok? Also looking at their Dura Grip LSD, thoughts?
doyouquaxu
26
Orange County CA
Ooo gonna do a 5 speed swap? I have some threads about it I've collected, Ill try to remember to send them to you when I get to my laptop. Using a combo of junkyard and new parts it can be done around 1k
Josh40601
MTOTM Winner
12
San Diego
The 5 speed is geared a lot lower than the auto. 5.12/5.13 on a 35 is going to be LOW. Like really really low. I run 4.56's in the yellow truck and with 35's, it's about right. I say 4.88s would be perfect for you.
Bennybooster
EMT / Paramedic
37
Medford, Oregon.
When I was planning on racing I was going to run 5.13's with 33's. For the desert and racing you want to be higher up in the gears at speed. I bet with 35's and a 3.0 I bet 5.13's would be about perfect
3.0ranger1227
11
3.0L
Kinda what I was thinking Benny.
Thinking about doing a good service on the engine to try and get a few horses back, what should I replace/service? Injectors, spark plugs, etc?
3.0ranger1227
11
3.0L
doyouquaxu
26
Orange County CA
plugs, wires, coil, seafoam it a few hundred miles before an oil change, clean IAC/MAF, clean air filter, fuel filter, 4.0 swap.
3.0ranger1227
11
3.0L
How bout a running 4.3 v6 in a vehicle with a mild cam for 1k? Runs strong too. Body, tires, and hubs are shot but the engine and tranny are good. It's an 03
3.0ranger1227
11
3.0L
Just got a donor engine
