Red Stepside build
3.0ranger1227
11
Thanks! It's getting the 4L60E that came out of the donor. I may find a reverse manual valve body for it and/or and different gear set. I don't like the jump between 1st and second, too much ratio change.
3.0ranger1227
11
Old school shifter.
3.0ranger1227
11
Josh40601
MTOTM Winner
12
San Diego
3.0ranger1227
11
Thanks! Now I just need to get her running
JTBeast3000
Mazda
How was the install on that shifter? And those wheels look sick.
3.0ranger1227
11
Shifter is easy. 4 bolts to the floor, a little bit of wiring, and a hole for the cable to run through. I haven't done the transmission side yet, but its just adding a bracket for the cable and changing the lever out. Trickiest part is trimming the black plastic piece.
Thanks!
3.0ranger1227
11
Got a little gas-saver commuter while this is down so I don't have to keep borrowing the parent's car.
2005 DR-Z400SM. Spent $9 to put over half a tank in it. Rather happy.
3.0ranger1227
11
Josh40601
MTOTM Winner
12
San Diego
well, looks like it fit
3.0ranger1227
11
Fit pretty nicely actually. Unfortunately have to go with stock exhaust manifolds to fit but such is life. Downhill slide now though.
Josh40601
MTOTM Winner
12
San Diego
shorties wont work?
Josh40601
MTOTM Winner
12
San Diego
Sounds like you need to move the shocks :D
