borjawil
- Jun 3, 2017
- 0
- Ford
1994 Ranger ext cab 4.0L 4wd
Current Info:
Burning coolant, replaced the driver head gasket and lower intake gasket. Fine for a couple hundred miles. Occurred again. Performed glove test on radiator. #5 cyl leaking. Replaced head gasket and coppercoted this time. Ford OEM lower intake gasket with black RTV on corners where head and block meet (front and rear) and on the surfaces of the block between the heads. Black RTV around coolant passages. New injector o-rings. New upper intake gaskets. New thermostat gasket at the block. Couple other new gaskets at throttle body, etc. After 1-2K miles its burning coolant again.
CEL Info:
CEL comes on when driving occasionally - usually at HWY speeds. This was occurring before due to a bad MAF and then an incorrect one. Correct one is believed to be installed now. Still getting CEL as before though it did go away for a while with the new/used MAF. Checked DTCs, only one for lean o2 on driver side. Not sure if thats due to o2 sensor or coolant burning on that side.
Coolant Reservoir and other symptoms:
One more thing i noticed. Heat isn't working, likely due to lowered coolant level. With temp gauge in high range no heat still. Loosing a lot of coolant I feel. no mixing in oil. where else would it leak from (obviously its getting in my cylinder since its burning). I also noticed that the reservoir cover is not sealed/deformed where the black top meets the opaque side and the overfill tube seal on top of reservoir is leaking/deformed. Assuming from hot coolant melting. Are there any issues with air getting in through here? I would assume it would affect the coolant system from creating a vacuum to suck coolant from reservoir to rad.
MAIN Questions:
I will be retightening the lower intake bolts again (driven 1-2K since last head/intake gaskets). Anything else I should check or do?
Will I show a blown gasket with glove test if intake gasket is leaking?
What is the proper torque spec and sequence for my lower intake and head bolts? Ive looked in the library on here and Ive also gotten information else where. I want to confirm these specs to make sure I didn't do something incorrect. Ive been told 13-15 and up to 22ftlb for the lower intake. Not sure if a range that great would affect it but I torqued to approx 16-18.
Thanks for sticking with me through that. Just wanted to cover all information for a better response. Ill get my glove test re-done and tighten those bolts and update.
Current Info:
CEL Info:
MAIN Questions:
