Replacement cab mounts - '92.. where to buy?
purpony
Im looking for replacement cab mounts for my 92 ranger... anywhere know where to purchase these? The only place i can find them (rears only) are ebay.... I need both front and rear......
anyone know?
thanks
Jspafford
Logan Andrew Feb 17, 2012
15
Lancaster, Ohio
Chevy 3500HD
6.6L
5"
Have you checked LMC truck?
pillen140
45
winston-salem, NC
james duff has 'em
purpony
I checked LMC catalog about 10 times... no luck.
Does James Duff have them listed online anywhere? have a link?
Or do i have to call?
thanks all
Sevensecondsuv
7
Northern IL
Many
All Fords!
Many
If you have access to a welder they're really easy to fab.
dude772
Caledonia, Ontario
5.0L
+1 thats what i did, cut the top off of mine that was thin as paper, cut a new flat piece, cut a hole in the middle. Then welded her up nice and solid.
trailblazer153
fabricating
Ok, so I want to fab it, but what thickness metal? 1/8?
Also, the bolts in the back do not come out. I'm a little nervous grinding and welding near fuel lines and a fuel tank. What to do?
DRanger024
487
Dale, WI
Solid Axle Swap 4x4
6-7” front maybe 3” rear
33x12.50-15
Nothing to be nervous about. Especially with the fuel lines. All you need to do is cover/protect the tank and have at er.
