1993rangerxl
- Apr 16, 2013
- 0
- Florida
- Ford
- Engine Size
- 4 banger 2.3L
Ok, here's the lowdown. Was leaking coolant into #3 cylinder, replaced head gasket, done ran fine before tear down. Now bearly runs at all. Bad miss, backfires up intake, backfires through exhaust also. No check engine lite. Checked timing, it is off 1tooth on the can, will fix that in the morning. What else should I be looking for? I'm thinking, plugs, plug wires, possible injectors?
Info, its a 93 four banger(2.3) manual trans, 4X2 base model truck.
