Safari Pacific MX2 Build
schanusa
November '08 OTOTM Winner
9
New Mexico
More of the same overlapping backing to weld on.
Roof welded into place. Since there is a lot of room for warping, I'll be taking a day or two to weld this up. I start by running spot welds a few inches apart. Over time I will continue to spot weld between the other welds until its fully welded.
While between welding the roof, I start to get ready to work on the wheel well of the cab.
More in a day or two...
Shoeboy
Calgary, Canada
Chrysler
2.4L
Excellent progress, what have you decided about the rear "windows", or are you undecided yet? I'm amazed at how quickly this build is going, I thought I'd see an update every month or so, and have it go on over the length of a year, its been, what a month and a half and you're about, what, a little under half done?
alaskan155
6
washington
FORD
7.3l/4.0l
an electric T-case,
:icon_surprised: might to swap that to a manual less stuff to go wrong
other than that this is turning out to be a great build
schanusa
9
New Mexico
an electric T-case, :icon_surprised: might to swap that to a manual less stuff to go wrong other than that this is turning out to be a great build
I'm going to try and fab up a manual shifter linkage where the electric solenoid goes. Shouldn't be to difficult.
Not All There
CT
awesome build! just stumbled across this, keep it up!
koda6966
61
The green part of NY.
2.9
I bet you could make good money if you built these for people.
schanusa
9
New Mexico
schanusa
9
New Mexico
To fill in the upper side panel, I start with constuction paper roughly cut and taped in place.
From the inside I trace where the pattern should be cut. After Cutting I tape it into place for a dry fitting.
Once the pattern is correct I trace onto sheet steel and cut out the filler panel.
At the bottom of the panel there is a small curve that I will have to recreate. I mark the top, bottom and middle of the curves position. You can also see the backing strips that I've been making to merge the bodywork together.
schanusa
9
New Mexico
Using a custom built bender I create the smaller curve.
Once bent into shape I clamp the panel in place and begin to weld.
Side shots of driver and passenger side panel in place.
Ranger44
23
Illinois
FORD
4.0 OHV
Nice....I like the way this truck is turning out.
holyford86
Some guy with a problem
649
Plattsburgh, NY
many
33x12.50R15
very nice work, very clean, excellent job.
fordguy64
cinci,ohio
very nice... i like it...
dusto2
scv ca
2.9
good luck to you on that one i tried, but its hard to make it rotate and stop at 4hi, and just rotate to 4lo is just under 360degrees, other than that great job i really like it, coming along quickly
schanusa
9
New Mexico
ROAD TEST!!! Before I get to far I wanted to see how much the new body parts rattled or puckered. This was the first time I had ever driving with ear plugs too... The wheel wells were open and created a lot of noise.
Couldn't resist photo-shopping a finished product.
The bed appears to twist quite a bit, although the rear cab mounts are not connected. This was a problem I thought I would have. With the frame flexing about an inch I worry it will tweek the cab. I may build a pivoting body mount for this.
All in all, everything handled well. None of the panels puckered or popped while driving. Now its onto finishing the wheel wells!
