sagging suspension
mwh0428
My front and rear suspension is sagging on my 1990 ranger by about an inch I will take pictures tomorrow. What would I be able to do to make it not look so bad?
scrapper
63
central IL
1975 302
6" suspension lift with a 3" body lift. Then it would look fantastic.
scrapper
63
central IL
1975 302
no pictures yet?
alwaysFlOoReD
5,129
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Tell everyone it's been lowered....
actually there is lots of help in the tech section, up at the top of each page in the blue header bar.
scrapper
63
central IL
1975 302
ratdude747
22
Madison, IN
215/70R15
Worn springs in the front. Could be the same in the back but rotted sagging rear spring mounts are such a common issue that I'd make sure that's all solid first.
IIRC springs aren't too pricey if you get them online... in a brick and mortar store, not so much.
