Scott B.'s Sleeping Platform Build
Scott B.
EMT / Paramedic
Georgia
'93
I have owned my truck since new (1993) and put an ARE Series 7 shell on it in 2000 - but to date, I have never slept in the truck. All my camping has been in a tent.
I planned a 2-week trip to the desert in the spring of 2011. We planned to run the Mojave Road for 3 days, then spend 6 days in Death Valley. I ran the Mojave Road in 1988, and had never been to Death Valley, even though I had lived in SoCal for 18 years. This was going to be quite a trip, since I live in Georgia now!
As part of my trip preparation, I decided to build a sleeping platform in the truck, to camp/sleep in. I brought my tent just in case, but the plan was to sleep in the truck.
In this thread, I will explain what I built (in words and pictures). I built this in 2 phases, but I will talk about it as one.
Scott B.
EMT / Paramedic
Georgia
'93
Starting Point
Here is the starting point.
I used to carry the spare tire in the bed, and it took up a lot of space. I also removed my Hi-Lift mounts and shovel mount.
Scott B.
EMT / Paramedic
Georgia
'93
The Plan
For building materials, I decided to use 1/2" plywood. I found some cabinet grade wood, varnished on one side. I cut 1/8" deep dados, and used glue to hold it all together.
I decided to build the platform in 2 sections. Since it was going over the top of the wheelwells, I could build it wider than 4'. Seeing as plywood sheets are only 4' wide, I had to turn them to get the needed length.
The forward section would contain storage compartments, including a compartment for a second battery.
With a general idea in mind, I went to work. Most of the dimensions were determined in place.
Scott B.
EMT / Paramedic
Georgia
'93
The second section would be accessible from the tailgate - no need for small compartments.
Scott B.
EMT / Paramedic
Georgia
'93
Installation
Since the sleeping platform is so wide, I had to remove the shell to install it.
Here you can see the forward section installed, the rear section installed, and the carpet cut (but not trimmed).
Scott B.
EMT / Paramedic
Georgia
'93
To be continued...
Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
TRS 25th Anniversary
8,824
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
Looks pretty interesting....
gregz240
San Jose, CA
I've done something similar with mine, but not NEARLY as sophisticated as yours. Just a plywood platform supported on 2x4s with a pull-out drawer underneath to store tools/camping gear. While I have slept in it, it's mainly for my contracting business. A quicky build.
TARDIS
That's pretty cool, I'll have to try something like that once I get a shell for my truck. Do you know roughly how much it cost for the supplies?
Scott B.
EMT / Paramedic
Georgia
'93
IIRC, I used 3 4x8 sheets of 1/2" cabinet grade plywood - check your local lumberyard (not Home Depot or Lowe's) for a price.
The through-bed hold downs were about $7/pair. Add L-brackets and bolts.
All in all, it was not that expensive.
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
Nice build, although I would have made the back half a slide out/pull out storage bin. Looks great!
SVT
Scott B.
EMT / Paramedic
Georgia
'93
Time to continue this thread...
I mounted a Viair air compressor under a corner of the platform. I also mounted an air tank under the bed - link
Scott B.
EMT / Paramedic
Georgia
'93
I installed a 2nd battery in the front right compartment. I put it on the right side for counterbalance weight, and forward to keep the charging wire as short as possible.
I put a Blue Sea Systems 12 point fuse block on a removable mount. There is room for 6 relays also.
Here, you an also see the bias tape edging I put on the carpet.
Scott B.
EMT / Paramedic
Georgia
'93
Next up is the refrigerator. For the longest time, I though a frig was a waste of money. I have changed my mind. It is expensive, but the convenience factor is huge. Really huge.
No ice to buy, no soggy food, no ice water with who knows what mixed in it. No having to hit town after a few days camping/exploring.
It's even great to have when you go out for the day. All in all, expensive but worth it.
The only negative is the size and how much room it takes up in the bed.
Here, you can see the process I went through to mount it.
First, where to locate it.
Mark and cut the platform.
Run power from the second battery.
Scott B.
EMT / Paramedic
Georgia
'93
Another test fit.
I built a sliding tray to mount the frig.
