screw removal on locking hub D44
swamprat
lexington KY
I have three screws on each lock out on my D 44 that I need to tear down and rebuild. any ideas to get them out? I have tried pb blaster and easy outs. Getting ready to drill them out if nothing else.
1badexplorer
Firefighter
4
Sutersville Pa
3.0, 501, 7.3psd, 351c, 351w
drill the head off then slip hub off and unwind the rest of the screw with pliers
swamprat
lexington KY
Yeah that was my next plan. I will get on it in the morning
Bent Bolt
4
Edmonton,AB
Supercharged 4.0 SOHC
Solid Axle Swap 4x4
Drill the heads off. Not hard to do.
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Impact driver with a phillips head bit on it usually gets them out for me if they are stuck or the screw head is in crappy shape.
swamprat
lexington KY
got one side off today. I will take the home to work and counterbore the hole again to give a flat bottom. I was able to turn the screws out by hand after I got the hub off.
metalmacguyver
Yeah, I built that.
11
4.0, 7.3
If its a stripped out hex, I hammer a torx bit into it. Either it comes out or the bolt snaps. either way, the hub comes of.
chico4554
CT
yea i doesnt take much to drill the heads off then get them out by pliers
swamprat
lexington KY
They are out. The one thing that I was worried about was drilll too deep. Now that they are off I see that was not a problem
