Seat belt refurbish
DandysRanger
13
North of Atlanta
2.3 FI
If you didn't build it; it's not really yours
Hey Gang, the driver's side seat belt was frayed about halfway thru so I sent it off to this place https://www.safetyrestore.com/ and it came back very shortly looking like new. When they say 24hr. turnaround they mean it.
Here's a tip: You can purchase the service on eBay from the same company and get free shipping.
Bronson
Manassas, VA
FORD Ranger
My seatbelt is not rolling back in, but according to DIY instructions on youtube, you can simply clean it with a soap and it will roll back again.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
thanks....on my 4th junkyard unit and it is whooped.
Craig0320
225
Mississppi
Break it right the first time. Fix it better the next time.
Is there an effective way to clean seatbelts?
Bgunner
1,085
Western Mass.
Ford/Ranger XLT
225/70/R15
You can use a soft bristle brush or tooth brush with dish soap and water to clean the fabric. A soft bristle brush is a must as a medium or stiff brush may snag the fibers and pull them a bit giving a fuzzy look to the belt. This method is usable on stains on your floor rugs to pull stains out and lift the fibers again. A pressure washer is Ideal for cleaning rugs but requires the rug to be removed where the brush, soap, water and shop-vac can clean the rug while installed.
Craig0320
225
Mississppi
Good info. Thank you.
