funny you mention snow, we got 5 inches on the ground that stayed yesterday and today, this is louisiana btw, not normal...then again the saints won the super bowl so i guess its just another sign hell froze over. i kno what you mean by seeing little riggings here and there. this 92 im driving had an alarm deal/no horn. removed that crap and installed a horn, but the wires for the factory switch dont work and it feels like its been removed. so i pull out the cigarette lighter adapter that is half hanging, run a butt connector to a switch on the bottom of the dash and run it to the horn with a chassis ground. the hood pull cable was a pain, so hard i ripped the piece of the dash clean off trying to open the hood, now i just have the cable stuck under the dash. my a/c lines are there but not capped, looks like somebody had fun with bolt cutters. im going to remove the lines and evaporator/accumulator cores and reshape the heater box for more room under the hood. plan on redoing the entire dash one day when the weather warms up (i hav a weeks vacation i need to use might as well make the most of it...) i also have new spring mount bushings, radius arm bushings, sway bar bushings, carrier bearing, 3 ujoints and torsion bars i am going to install as well. shes been a slow project including new doors/mirrors, vacuum gage, new front pads/rotors/bearings, rebuilt 7.5 3.73 rear end, new rear drums/shoes/hardware/axle seals. all started when i bought it with a busted a tranny, stuck in 4th busted 2nd and 3rd with stripped synchros, jy 97 b2300 trans went in. add that to the radiator power steering pump/pulley/hose, idler pulley, serpentine belt, timing belt, plugs/wires/coil packs, throttle cable mod and air filter relocation id say ive been busy. picked it up for 400 bux, was walking when the 93 acted stupid on me and fig hell if i can rebuild it for 8k and 5 or 6 yrs out of her what the hell. heres some pics of what im working with.
ps i also did the floorboard mod, redid shiftrail plugs with pipe plugs and new shifter bushings, was either pull the tranny again or cut a hole. i plan on building a diamond plate cover that can be removed as well for future access, just low on funds atm.
