Slave cylinder went out. Fuuunnn
chewy012
Colorado Springs, CO
4.0 OHV
Lost the slave cylinder yesterday just as I got to my destination, 80 miles from home. Slave cylinder gushes from the wheep hole at every pedal pump. I was able to get outta downtown denver with only 1 clutch application and back into my town with another 2.
Boy howdy, how I can't wait to do this job.
Of all the ways to breakdown, this was about as good as it gets haha. Also, my buddy towed my f150 about 6 blocks with is 1.6L fiesta. That was a good picture haha
Sent from my VS988 using Tapatalk
8,372
Bummer :sad:
External clutch slaves didn't last as long but were easier to change
chewy012
4.0 OHV
Yeah, i'd take an external slave any day
rusty ol ranger
2.9 Mafia-Don
7,582
Michigan
177 CID
chewy012
4.0 OHV
If anyone is still listening, I just replaced the clutch and slave/tb, and its not feeling right. The pedal feels fully bled, in that, the pedal is firm with the hydraulic line disconnected, and prying between the tb and clutch fingers is tight. I've gone through bleed procedure about 6 times since the I plugged the line back in. The pedal feels a lot easier than it did with the last clutch, and it releases way at the end of the pedal. With my arm I feel the consistent spring back force all the way through the pedal, but it does feel like anything with my foot.
My book said 20-29 ft-lbs for the pressure plate, and I did 10 than 20 and stopped there as the bolts felt tight.
Do I need to tighten it down more?
I drove it to work this morning, it feels ok... Seems to shift gears well enough, but theres no feel to the pedal. And the end of the pedal grab I don't like. The clutch was the M-PACT 07097ST1 on rockauto, with which has almost a full face of material. The old one had only had about a 1 inch ring of material around the outside.
Also, I noticed with my foot on the brake, it starts to pull the idle down at about 3/4 and I can bring it to a stall, but again, it's like there's nothing there.
I've never had a clutch feel like this
chewy012
4.0 OHV
Haven't made any changes, about 500 miles in, no troubles. Huh.
adam762
Washington Court House OH
i used a slave cylinder i got from Rock Auto in mine when I did it last spring. It certainly did feel different! Smooth and effortless. Took a bit to get used to the new 'feel' but I'm 6 months in and it's been peachy for a while. It just felt like it released differently.
Denisefwd93
74
South East PA
When we changed out the bad M5OD, We used a rhino pack pre bled clutch slave and master from RockAuto. We did not replace the clutch and flywheel because there was plans to change the engine out but the engine runs so darn good and doesn't use very much oil so that may have been a mistake. This pedal feel is right at the top and only takes a slight pressure to disconnect but there is pressure all the way to the floor so my assumption is it's a very worn clutch disc, I don't like that it requires quite a bit muscle and I hope that will change with a new clutch someday
chewy012
4.0 OHV
Yeah, mine seems to have settled in. Actually, it feels better than the old one the PO had in there. I like it. It definitely felt really light, but now that my leg is dialed in to it, it feels good.
