Snap ring needed
LAndrus
Replaced the L front hub on my 99 Ranger 4x4. The snap ring inside the hub that holds the plastic ring in place is shot. My local parts store doesn't carry anything similar(Advance Auto, go figure).:annoyed: Does anyone know the part number of that ring or an aftermarket ring I can locate. The truck is deadlined until I can locate it :sad:.
Thanks
Tractor Dan
Near Lima, Ohio
Do you have the snap ring that was there to begin with? If so i would venture a guess you could go to lowes or some place that sells snap rings and might find it. Just depends if it's a common size. Another place to check is Napa if you have one near by. Sometimes they will have parts like that which stores like Advance don't.
Andy D
10
Marshfield MA
The Rat
4.0 OHV
to prevent Found On the Road Dead, Fix Or Repair Daily
Another spot to try is ACE hardware
